Zum Hauptinhalt wechseln
The Asus ROG Strix GL702VM-BHI7N09 is a gaming computer released by Asus in January 2017.
20 Fragen Alle anzeigen
Rog gaming center will not open! Freezes my cp? D:?
'''MY DEVICE WASNT MENTIONED :
ASUS ROG GL753VD-DS71 17.3" Intel Core i7 7th Gen 7700HQ (2.80 GHz) NVIDIA GeForce GTX 1050 16 GB Memory 1 TB HDD Windows 10 Home 64-Bit Gaming Laptop'''
I changed a power setting on the ROG Center, a few weeks prior. After two days, My laptop had an update and had begun to freeze and did not work further-- till I'd have to press the power button for it to be usable. It now does this this every 24 to 36 hours (estimate)?
I close my laptop almost every day and I dont know if that's the reason. But, i started doing some research then realized: It could have been the ROG center. So i thought, okay, simple fix, I'll just revert those changes.
NOPE. The button does nothing but, show that it's processing on my mouse/arrow.
I'd wait a while, nothing.
I'd restart my cp, nothing.
I don't know what to do.
Please help :)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
1 Kommentar
Prepared as well as check in to your itunes account to access your tunes or downloads. https://ituneslogin.us/ iTunes Log In and also responding to much more concerns.
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Delete the app.
Download the appropriate drivers
Right click and extract the ZIP
Check for subfolders marked setup.exe
Select update or install drivers
Allow unit to reboot
;) Not an expert, I asked on asus chat.
Fixed it babeeee
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Delete the app? so how i can find it?
von
have you tried to system restore ?
Bewertung 0
1 Kommentar:
Yup.... no go.
von
search rog gaming center , open and activate rog key! very easy! good luck!
Bewertung 0
So, I dont mean to revive a REALLY old question, but i have been plagued with this issue myself for a long time with my ROG STRIX GL702VSK Laptop. ROG Gaming Center worked fine for around a month, then it all of a sudden stopped working. The ROG Key would not work, nothing. I would get the “ROG Gaming Center is initializing” popout, then nothing. I went digging around in the directory for the program (in my case it was “C:\Program Files (x86)\ASUS\ROG Gaming Center”) and i found an executable file (.exe) by the name of “LaunchROGGamingCenter.exe”. I ran this program as an administrator, and the application OPENED without issues! i made a shortcut on my desktop, and now it is as reliable as the day i got the laptop! Hope that helps somebody!
Bewertung 0
Antwort hinzufügen
Paula Pereira wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 23,545
