Zum Hauptinhalt wechseln
Es handelt sich hierbei um den Nachfolger des LG V10 Smartphones, der dem LG G5 ähnelt und am 29. September 2016 auf den Markt kam. Das LG V20 ist durch folgende Modellnummern gekennzeichnet: F800, H910, H918, H990 DS Dual, H990N Dual, H990T, LS997, US996 und VS995. Es ist in titan, pink oder silber mit 32/64 GB Speicher verfügbar.
20 Fragen Alle anzeigen
USB C port replacement
What is involved in replacing a damaged UCB-C port on the LG V20? Actually, I could ask a similar question for my iPhone 6S Lightning port. It's been pointed out that one advantage to "wireless" charging is the reduction of wear on power sockets. With daily use, that would be around 700 plug ins over a two year period, so wonder if this comes up often as an issue, and if so, how to replace a damaged power port.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
heres a video of the disassembly https://www.youtube.com/watch?v=5yC0ROV3.... to do the replacement you will need a hot air station, a soldering iron, flux and some leaded solder
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thanks. I'll review the teardown you supplied.
von
It can in fact be removed and replaced, but you definitely need a hot air rework station, in my opinion. I did find a YouTube video by a very talented person who was able to do it without a hot air rework station. The video is very well done, and I only wish I had his talent and steady hands.
https://www.youtube.com/watch?v=WgXMjRAU...
I took an old broken LG V20 logic board and was successfully able to remove the connector without damaging the board using my rework station. However, due to the heat, the connector that was removed did not survive. The board was fine, and no other SMD parts were moved or appeared damaged. I know that you can purchase the connector itself on Ebay. Be aware that it has both surface mount pins and 6 thru hole pins as well.
Bewertung 2
Antwort hinzufügen
William Vaughan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 19
Insgesamt: 5,173
