Zum Hauptinhalt wechseln
2,5 GHz Dual-Core Intel Core i5 Prozessor (Turbo Boost bis zu 3,1 GHz) mit 3 MB geteiltem L3 Cache.
265 Fragen Alle anzeigen
MagSafe isuues: intermittent but mostly never charges.
My MacBook MagSafe adaptor began working intermittently at first then not at all. I checked the connection and looked for obstructions, none found. Checked the depressable pins , all working as designed. Bought a new charger, worked but only charged to 40 % before lights out! Now I have two chargers that won’t light up or charge.. tried several SMC. Resets to no avail. Purchased new MagSafe board and replaced. Still not working. Checked prices on logic board, around $400 plus. Seems too much to invest in 2012 model. Apple wants over $700 which definitely is not worth it. Does anyone have further suggestions of what I could try? Strangely, every once in awhile I will play with the chargers at the magnetic connection and the light will go on and start charging. As soon as it is unplugged and plugged back in, no light & no charge. I have tried with and without the extension cord that comes with the MagSafe adaptor with the same results. MacBook runs surprisingly well and fast for its age. Hoping to salvage!
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Same issue with mid-2012 15" MBk Pro
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
I would remove the bottom of it and check very closely for any signs of logic board corrosion first. More than likely your board will require repair to remedy the issue.
I have seen a lot of older MBPs that have wear on the MagSafe connector that can cause intermittent charging issues, but since you've already replaced the board, that's probably not the problem. You may want to try another new one just to double-check, though.
War diese Antwort hilfreich?
Bewertung 1
My 15" mid-2012 MB Pro has the same issues, but I have not replaced anything other than the charger itself. (Same issues with a brand new charger!) I'm thinking it's the mag-safe connector/circuit that has gone bad from too much stress on the connector while it was plugged in. I have worked mostly with it plugged in since I bought it new. I have owned several Mac laptops and have never seen this problem before on any of them...
Bewertung 0
Antwort hinzufügen
granitestatebuilders wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 6
Insgesamt: 125
