Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s Plus gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
1041 Fragen Alle anzeigen
Broke the lightning connector - parts stuck in logicboard
Hi.
My phone won't charge. I replaced the battery and the phone lasted for some time (20% remaining on new battery). Then I bought a new dock connector to try. The problem is that when I disconnected this, half of it got stuck in the connector.
Is this repairable? I have not been able to pull the parts out with my 0,8mm flat screwdriver.
Any advice and help is much appreciated!
Se link for pictures of the contact.
Thank you
https://imgur.com/a/Nyzkh
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare
try a set of fine point tweezers
von
Bought some tweezers. Didn't help and I guess it's getting more and more damaged now...
Will this repair be comparable that of the Tristar replacement then? Maybe a repair shop that does microsoldering can do them both(?)
Thank you for your reply, daniel.
von
you will just need someone that can microsolder to remove the old connector and solder on a new 1
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
It seems like corrosion made those connectors stick. You have to replace that connector and inspect around logic board to make sure there is no more damage on the logic board. If you are not a micro solderer id recommend finding a shop who can help!
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Bjørnar wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 109
