Zum Hauptinhalt wechseln
Battery operated RC truck designed for rock crawling and off-road terrain. Made by Maisto Tech.
17 Fragen Alle anzeigen
Can the truck be tested or powered on without a remote?
We bought a used truck at a thrift store, and it didn't include a remote. Before we invest in a replacement of the remote, we'd like to test the actual truck to make sure it works. Is there any way to test the vehicle without a remote, such as turn on the motor?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi!
Yeah, you could theoretically wire up some batteries to the motor if you can access the main circuit board and see in it does anything. While I don't own this this thing personally and never tried this, I don't see what could go wrong. Just be sure to wire the batteries/ power source up properly and avoid applying too much power.
PS: This will also be helpful.
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
EJ M wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 11
Insgesamt: 132
