Zum Hauptinhalt wechseln
Der Mac Pro (Anfang 2009) kam im März 2009 auf den Markt. Er führte erstmals die Nehalem Architektur von Intel in die professionelle Apple Desktop Reihe ein, und verfügt über ein leicht neu konzipiertes Inneres, das auch bei den 2010 und 2012 CPU Updates beibehalten wurde.
201 Fragen Alle anzeigen
Fan rev max speed when using only one CPU. Is this intended?
Hello.
I use Mac Pro 2011 (12?) with dual x5670 CPUs.
When I try to boot with one CPU removed, it gets fans rev max speed and makes hugh noise.
These are my attempt :
2 CPUs - normal
1 CPU on socket B - no boot (blink white led)
1 CPU on socket A - boot, but fans rev max speed.
1 CPU A with 1 cooler - max rev
1 CPU A with 2 coolers - max rev
I know swap with the different firmware CPU tray makes max fan, but thats begin immediate booting. In this case, it start with normal quiet, but getting super fast after a minute or two. Either Mac OS and Windows.
Also I found not important much but wierd symptom, CPU temp is very normal, but TDP is always max(checked HWMonitor on Windows).
Is this intended behavior? Like alarm for broken or not recognise one CPU or stealing one?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
When doing any major changes like a CPU change, you will need to use the original system installation disk and run the fan syncing software, or you will get run away fans issues.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
About the "fan syncing software" you mention, I searched the web and all I can found is your answer on another question thread. There is no trail about that in anywhere and even can't find it's name.
Is that really exist? If it is, can you tell me what's it's name or procedure?? I do have both OS X Installation Disc and Application Disc, there is no obvious "fan syncing software" or similar one.
von
Antwort hinzufügen
Anonymous wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 153
