Zum Hauptinhalt wechseln
An affordable sporty coupe hatchback designed with the intention of installing aftermarket components with ease. Contains a 2.5L, 6 speed engine and is manufactured by Toyota through Scion.
6 Fragen Alle anzeigen
Heated seat (under the seat wiring diagram)
I have a 2011 Scion TC with leather heated seats and the heated seats are not working. I bought this car used from a dealership 2 years ago and am just getting around to see if I can fix the heated seats. My first thought was the fuses were bad. I switched out the fuses and still not working. I see a plug under the seat that is not plugged in to anything.
This may or may not be the problem, but I can't seem to find where this plug would hook up to. Have been trying to find a wiring diagram or some sort of tutorial online and just cannot find one. Can you help me with this?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
https://files.acrobat.com/a/preview/1473...
Here is a link to the wiring diagram of the heated seats.
Also it'll be easier to see whats going on if you were to remove the seat so you can see under it better.
Hope this helps
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thank you!!!
von
Antwort hinzufügen
hmg7899 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 1,424
