Zum Hauptinhalt wechseln
Kam im Juni 2016 auf den Markt, in Europa anhand der Modellnummer A3003 zu identifizieren, in China und Nordamerika mit A3000 (entsprechend https://forums.oneplus.net/threads/oneplus-3-regions-model-numbers.452381/)
66 Fragen Alle anzeigen
Dissabling the microphone on the OP3
Hello,
I read this story on wired How to Rip the Mics Out of Your MacBook and iPhone . Would it be similar for the OP3?
This is because I could find any obvious cables on the dismantling tutorial.
Cheers!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
How Can I'll be Correct Microphone
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @radconnorcon ,
According to this link the microphone is on the charge port flex cable.
Here is a link to the ifixit Oneplus 3 Teardown guide. At 4:11+ minutes into the video the microphone is accessible.
You could always try gently (stress gently) permanently removing the microphone from the cable and then re-assembling the phone. (I doubt that the microphone would be able to be reinstalled successfully - you'd most probably have to install a new charge port + microphone flex cable)
Hopefully the phone should still work if you use the earphones with the microphone attachment if you feel the need to make or receive calls.
Alternatively you could just simply block the phone's voice inlet hole on the bottom of the phone with glue or perhaps as a temporary test measure, clear adhesive (sticky?) tape to prevent sound reaching the microphone. This should achieve the same result with less potential damage from having to open the phone etc, occurring
Glad I'm too old and hopefully considered not interesting enough for it to be worthwhile to be bugged by anyone. Life's simpler this way. Cheers ;-).
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
Conrad Connor wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 857
