Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Error 4013 iPhone 6
The iTunes will stage, 'waiting for iPhone', and then into, 'preparing software for iPhone'. I will then go back to 'waiting for iPhone' and crash, ending in error 4013! It is otherwise in a constant loop. I cannot access and settings!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 16
3 Kommentare
1. Do a Factory Reset of your iPhone Device
2. Clear Cookies, Cache, and History from your iPhone Device
3. Reset your iPhone Device
4. Use RecoveryTool
http://bit.do/exGXL
von
Will this get rid of that code and make phone work with no further issues or once the error has already popped up are you screwed ?
von
Iphone 6 getting same error 4013. I just replaced broken screen and display ok but since getting error 4013. new part in good condition as well try almost 4 computers still same! Only thing diff is miss the metal part above the display cables. Can be cause the 4013 issue ?Appricate your help! Thank you
von
Einen Kommentar hinzufügen
7 Antworten
Gewählte Lösung
Error 4013 is a board level issue that only people that have micro-soldering skills can fix.
This may involve one or more of the following:
- Removing the NAND memory chip and reprogramming it
- Diagnosing and fixing the power circuit(s) going to the baseband or processor.
War diese Antwort hilfreich?
Bewertung 11
1 Kommentar:
Check the condition of CPU power supply or components on power supply rails. Or check if the CPU is pseudo soldered or damaged.
Here we have a repair guide for fixing iPhone 7 error code 4013 for your reference: https://blog.rewatechnology.com/how-to-f...
von
This error could be due to multiple issues, In short the error is a connection error that is telling you that there is a communication issue between the device and the PC. Here are some solution
  1. Try a different cable, preferably an official Apple Lightning cable
  2. Try a different USB port
  3. Clean out the Lightning port, lint is sometimes in there not allowing a good connection, use a pick to clean it up
  4. Try a new charging port, sometimes these port get worn and need replacement. This could be causing that error
If all of these are tried and it still doesn't work unfortunately you have a motherboard issue which unfortunately would need a motherboard repair which most often is not cost effective. Hope this helps, best of hopes!
iFixit iPhone 6 Lightning Connector Guide
Bewertung 2
Using Joyoshare UltFix can repair your iPhone error 4013 without data loss. I have tried myself.
Bewertung 1
Download Reiboot on your PC and connect iphone to pc. Then click on “Exit Recovery Mode”. Thats it.
Bewertung 0
but my iphone 6 ill still error 4013 again
Bewertung 0
1 Kommentar:
did you try Reiboot?
von
i got same issue always Stuck on iTunes. Then Imyfone they help me out repair it and now working fine.
Bewertung 0
1. Connect your iPhone 6 to the computer. Open up the iTunes utility.
2. Make a backup of all your user data or it will be erased.
3. Upon finishing the backup, disconnect your iPhone and turn off iTunes.
4. Open the Recovery Mode by holding the Power and the Home button at the same time until the black screen appears.
5. Now open iTunes from the PC.
6. Connect your iPhone, iTunes will indicate “Device is connected in the recovery mode”
7. Now follow the simple instructions and restore your device. Result in; your data will be wiped out.
8. Restore your data from the backup you made earlier.
Greetings,
Peter
Bewertung 0
2 Kommentare:
Idiot phone never on stuck on apple logo how to backup data u moron
von
@janigamer Please, no name calling. Antonios went to the trouble of trying to help and it does no one any good to discourage them and make sure they never want to try helping someone again.
Yes, you can certainly point out that being stuck on the Apple logo means the phone cannot be backed up, but the rest of the information about putting the phone into recovery mode could conceivably help someone, but calling them a moron isn't called for.
von
Antwort hinzufügen
Cody Potato wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 37
Insgesamt: 34,755
