Noise gitting louder from front tires.
How do you remove wheel bearing housing from front spindle. Need to know how to git it off the spindle.
Ist dies eine gute Frage?
dougewalk, this job needs some heavy presses. PITA to do it, but in short it goes something like this
Remove steering knuckle from car
Press hub flange out of old wheel bearing
Cut/press bearing race off of hub flange if the bearing explodes coming apart
Press bearing out of knuckle
It isn't a really hard job if you have the tools, like a 20 ton press. Also make sure that you know what you push on when you replace the bearing so you do not ruin the new bearings. Oh, just found some more instructions right here Well, good Luck to you and let us know how it is going.
War diese Antwort hilfreich?
+ this really sounds like a job for a professional
I'll second that-- anything to do with steering. +
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,289
