Zum Hauptinhalt wechseln
The Motorola DROID MAXX is the successor to the Motorola DROID RAZR HD.
31 Fragen Alle anzeigen
Shows charging but then says isnt charging
I replaced a customers screen and battery on their Droid maxx 2 and now the phone shows the lighting bolt saying the phone is charging but when I go to the settings and go under battery it states that the phone is not charging and the battery percentage is not moving, can someone please help me with this issue? PS I removed the wireless charger per customers request
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
there is a possibility that the port isnt transferring the current properly. i would suggest replacing the port, to see if that works.
however, you could have a board failure, or software corruption as well. a factory reset would fix a software corruption.
War diese Antwort hilfreich?
Bewertung 0
If it wasn’t the battery that is busted then it means that you are using a power adaptor that is not giving enough power to charge it. I do hope that the phone is currently is working! Sorry if I came in way late.
Bewertung 0
Antwort hinzufügen
cellphonebuyer1 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 100
