Zum Hauptinhalt wechseln
Modell von 2011, A1278 / 2,4 GHz i5 oder 2.8 GHz i7 Prozessor.
591 Fragen Alle anzeigen
How to install OS Sierra on new Hard Drive?
I recently replaced my 750GB Hard Drive with a new 1TB. Currently I have it running on OS Lion, but want to update it to where I can install OS High Sierra, but I can't seem to do it. How can I update my new hard drive without having to go to the Apple store. I've tried making bootable disk drives but they wouldn't work.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hi melespinoza21
you can consider following the below link for the guide to download high sierra.
http://osxdaily.com/2017/09/27/download-...
https://www.macworld.com/article/3204672...
I used the High Sierra patcher application to create the usb, as I had difficulties in downloading the full package, only 19MB, as it should be 5.2GB
I would recommend you to backup important data first, use the appstore to check for any system updates, e.g. like firmware, before proceeding to the next step on clean install
get a usb thumbdrive, preferably 16GB to make a usb installer.
In Summary
1. Check for any system updates and Backup important data / settings
2. Make bootable USB High Sierra Installer
3. Power Off and ON the Macbook, holding Options to to boot on the USB installer
4. When in installation menu, Use disk utilities to manage your system partition.
5. Install OS
War diese Antwort hilfreich?
Bewertung 0
o make sure Sierra has no troubles installing and works fine after, you need to get rid of system junk on your Mac first. You could clean it up manually, but using a cleaning app like CleanMyMac 3 will save you hours on that. Junk removal with CleanMyMac takes only a few minutes. Download CleanMyMac for free, launch it, click Scan, and then Clean. Now you’ve got plenty of free space and your Mac is free from system trash. Download TuTuapp for Mac
Bewertung 0
Antwort hinzufügen
melespinoza21 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 4,207
