Zum Hauptinhalt wechseln
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Die Reparatur dieses Geräts ist ähnlich wie bei den Vorgängermodellen und erfordert Schraubendreher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
3530 Fragen Alle anzeigen
Why my Battery drains so Fast?!
Hi there!
I have an iPhone 5S which I traded a broken Galaxy S6E for.The phone looks good, problem is that the battery drains a bit quicker than expected. It gets a bit warm but very little. It continues to drain overnight or in my pocket, Wien 20/30/40% randomly shuts down and it doesen’t accept all the cables. He gave me the original cable which seems to work for now.I’ve read on the Internet that it may be iOS 11.2.1 that causes issues, but not sure.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
If it dies fast and you tested the battery, you have a faulty U2 IC chip and needs to be replaced and resoldered!
A board level technician will be able to replace it for you!
Also using third party cables and modified cables can also blow the U2 IC Tristar chip on the board and you get those symptoms!
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
Check the health of the battery using one of these:
Windows: 3UTools
Mac OS X: Coconutbattery
iOS: Battery Life
If your battery health is close to 80% or lower, consider replacing the battery.
You have a few options on getting a battery replacement, either by:
- Doing it yourself (DIY).
- Taking it to a mobile phone repair shop.
- Taking it to the apple store (booking a genius bar appointment).
Guide to replace the battery:
iPhone 5s Akku tauschen
You can buy a replacement battery from iFixit here:
iPhone 5s Battery
iPhone 5s Battery Bild
Produkt
iPhone 5s Battery
$29.99
Bewertung 3
3 Kommentare:
https://imgur.com/a/K4WhZ
Battery life seems ok I think...
von
Yeah battery life looks okay.
Backup your phone first, then do an restore via iTunes then restore from iTunes backup, sometimes this helps with rapid battery drain when the battery health is good.
iTunes backup stores your photos, contacts, settings and some app data. You will need to sign in to certain apps again after restoring the iPhone.
von
I've already done that, from what I see, instant amperage is pretty low (120mA)... maybe is because my cable was repaired. Anyway, I'll be swapping the back case with all the components soon and I'll post a comment here as an update if I fixed anything. Have a great day !
von
Stay away from the ‘Battery Life’ app… it’s a total rip off, and will tell you nothing more that what you already know about your battery. It gives absolutely no info on ‘wear and tear’ percentages etc… all it will tell you is how much % in charge it has left, which of course you already know! The better app to get is ‘Battery Testing’.
Bewertung 1
Antwort hinzufügen
Andrew Drift wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 14,344
