iMac does not boot up Led 4 on mother board only
the only thing that powers on is the hard drive and I only have led 4 on the mother board, Ive already change the power supply but no change.
Ist dies eine gute Frage?
Here's the on-board Diagnostic LED info for reference. Your logic board appears to have issues not your power supply. Can you give us a bit more on what happened with your system.
LED 1 - Indicates that the trickle voltage from the power supply has been detected by the main logic board. This LED will turn on when you connect the iMac to a working AC power source. The LED will remain on as long as the computer is on or asleep.
When the computer has been shut down correctly, LED 1 behavior may differ:
If a startup event is scheduled in System Preferences/Energy Saver, LED 1 will stay on after a correct shutdown. If no startup event is scheduled in System Preferences/Energy Saver, LED 1 will turn off and will stay off as long as the power cord is kept connected and an AC power source is present. Disconnecting the power cord and plugging it back in will turn this LED back on, even if the computer is still off.
After disconnecting and reconnecting the AC power source, this LED could remain off: If the AC power source is missing or disconnected.
If the logic board is disconnected from the power supply or the AC receptacle.
If the power supply board is faulty.
LED 2 - Indicates that the computer is turned on. This LED will be on as long as the computer is turned on (but is not asleep) and the power supply and voltage regulators are working correctly.
LED 3 - Indicates that the computer and video card are communicating. This LED will be on when the computer is communicating properly with the video card. If LEDs 1 and 2 are on and you heard the startup sound but LED 3 is off, the backup battery (on back of logic board) may need to be reseated or the video card might be installed incorrectly or need replacement.
LED 4 - Indicates that the computer and LCD panel are communicating. This LED will be ON when the computer is turned on and a video signal is being generated. If LED 4 is on and there is no image on the display, the LCD panel or the cables between the LCD and logic board might be installed incorrectly or need replacement.
LED 1 = Power is available.
LED 1 + LED 2 = Power is available and the system is turned on. If the second LED is not visible when the power button is pressed:
LED 1 + LED 2 + LED 3 = Power is available, the system is turned on, and the GPU was found.
LED 1 + LED 2 + LED 3 + LED 4 = Power is available, the system is turned on, the logic board is communicating with the GPU, and the internal LCD was found.
War diese Antwort hilfreich?
does Apple not have an answer for led 4 on only nothing in the service manuel explains whats wrong when its on led 4 on and the drive works.
Check on everything above still no change
Please give us some background info what happened before it stopped working.
This is all there is so you have a really messed up logic board if only #4 LED is lit. Are you sure you haven't reversed the order. Apple doesn't make note in the manual what the order is of the LED's so I'm thinking the bottom one maybe #1 here which would make more sense.
If you have power and no beeping sounds but no image on the screen then it is possible a GPU issue. It seems the gpu on this model is soldered onto the logic board. You can send it off to have the logic board reballed or you can replace the logic board.
if the mother board responds when you place the wrong kind of drive in it would that not say the board is working?
In my case (iMac late 2012, A1418, i5 2.9GHz) LED 1 + LED 2 + LED 3 is ON, LED 4 is OFF when is display connected on board. When then connect adapter miniDP-HDMI on TV, just black screen on TV. When disconnected iMac's LCD then I have image from iMac on the TV, but internal fan in iMac is loud (because temp.sensor on LCD). Still, LED 4 is OFF. I was inspected the LCD display cable and motherboard but no visible damage. I'm confused...
@Zeljko Devic - Without knowing what lead up with the systems current state its hard to tell what needs deeper inspection or replacement.
Whats the background: Where you upgrading or did it just stop working?
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 56
Insgesamt: 1,845
6 Kommentare
@galipeau you have verified that this is LED 4 and not LED 1? LED 4 will be ON when the computer is turned on and a video signal is being generated. That implies that your computers power supply etc. would be functioning as well. Therefore at least #1 and #2 LED would be on as well.
von oldturkey03
LED 123 are off it was rebooting and just stoped .
von Denis Gregoire
@oldturkey03 - I haven't needed to diagnose one of these using the LED's yet.
I do have the manual and it doesn't make note of the order of the LED's. I looked a bit online I don't see anything other than the older systems.
I'm thinking Apple has the bottom one set as #1 If one twists ones head to the left then that would read from left to right 1 > 4. Besides the fact #1 needs to be lit suggests this is then the order.
von Dan
@galipeau post a couple of images of your diagnostic LED's and point out which one you find to be lit. Bilder zu einer vorhandenen Frage hinzufügen
von oldturkey03
Ok I will add photo of the led though top to bottom it’s the bottom last light
von Denis Gregoire
1 weiteren Kommentar anzeigen
