Zum Hauptinhalt wechseln
Released March 2006, identified by model D620 on the keyboard bezel.
dell d620 not trying to start
ok, so my Dell d620 won't power on, i bought a new battery and adapter just in case that was the issue and still wouldn't power on, ill hold the button for 30-45 seconds and the lights won't even come on the fan dosent start its like its dead, but the battery has power, the adapter works on my other laptops, any help would be appreciated
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
if your battery has charge, and the device wont even show a sign of life, you likely need a logic board replacement. unless you have a background in board troubleshooting, and can find/repair the failure on the board itself.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
thanks for the answer
von
If it is not getting power then I would start with the ac/dc jack on the laptop.You can start with a muttimeter by measuring resistance and making sure you are getting a good connection. This jack seems to be soldered to the board so replacing it may take some elbow grease.
Testing the Jack
Here is a video on how to disassemble
Update (01/09/2018)
Here is a video on desoldering the old jack and adding a new jack to the board.
Bewertung 0
Antwort hinzufügen
jack D wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 15
Letzte 30 Tage: 36
Insgesamt: 623
