Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
2329 Fragen Alle anzeigen
iPhone 6s makes static noise when phone I’d unlocked
Hi
This is a new thing for me. Did a charging port change on a iPhone 6s and everything went great did change the proximity cable and front camera at the same time.
But when I started the phone it did a really low static sound witch you allmoust could not hear. So I tried calling and the same noise was there but off course higher when the mic did pic it up.
So I decided to change the chagrin port to a new one, and I did but still the weird sound. Haven’t heard anything like this befor. Anyone got a clue what it could be?
And the weird part is that every time I lock the screen the noise goes away and when I unlock the phone the noise starts again.
Happy hear all answer that can help me!
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Kommentare:
Il try changing the speaker as soon as i can then. But is the speaker only active when the phone is unlocked? The sound is only there when the phone is unlocked?
But thanks il try changing it.
von
When my phone is near my tv the tv makes a static noise why?
von
Einen Kommentar hinzufügen
Nintendo Switch Kits
Eine schnelle Lösung, um wieder ins Spiel zu kommen
Switch Kits kaufen
Switch Kits kaufen
1 Antwort
Gewählte Lösung
Either the connection to the bottom speaker (loudspeaker / ringer) is not good or the bottom speaker needs to be replaced.
Here is where to buy the part if you want to buy a replacement from iFixit:
iPhone 6s Loudspeaker
Here is the guide to replace the bottom speaker:
iPhone 6s Lautsprecher Austausch
iPhone 6s Loudspeaker Bild
Produkt
$24,99
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Kristian wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 3
Letzten 7 Tage: 12
Letzten 30 Tage: 60
Insgesamt: 4,418
