Hi,
What is it with dogs and the Sennheiser RS120?
Here is a link to a question (in Dutch) where the person had the same problem
Kabel aan dockingstation gebroken
In essence the paraphrased and translated answer to the problem was :
There are two screws on the side of the unit that need to be loosened (or removed). After that use an old plastic credit card (or similar) along the edges of the white front panel to pry it loose. You'll then have access to the cable etc.
Hopefully this is of some help
Original reply
Aan de zijkant heb je twee vijzen dat je moet losdraaien, dan kan je, mits gebruik van een bankkaart of iets in die aard (dat je nadien uiteraard mag weggooien), het voorste 'witte' paneel ervan halen als je met de kaart langs de randen alle contactje losmaakt.
Google translation
On the side you have two screws that you have to loosen, then you can, with the use of a bank card or something like that (which you can discard afterwards of course), the front 'white' panel of it if you go with the card along the edges loosen all contact.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
3
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
