Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Welcome screen keeps returning after reboot
Hi all,
I transfered all my data from my iPhone 4 to a iPhone 6. Everything went well and the phone is working fine.
After that I rebooted the phone and the 'Welcome screen' was back. It says the phone is installed correctly, you can use the phone etc. After that I have to choose a WiFi connection. And than the phone works again good. This happens everytime when I reboot the phone.
I also tried this without the backup on the phone, and when I rebooted the phone this time, it does not show the welcome screen. What could be the problem?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
a few different things have fixed this issue in my shop before.
1) most commonly, a Hard reset fixes it. (Power and home for 15 seconds)
2) sometimes, when i replace the battery, and this goes away.
3) there is a row of components on the board, if these take any damage, it can cause issues with the battery. if the board doesnt recognize the battery when its off, it will reset all the setting on your device.
4) Forcing a fresh restore onto the device. manually downloading the iOS, and using the DFU mode to force it onto the phone can help this issue.
That being said, there has been times where i have been unable to fix this issue without a logic board replacement as well.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Thanks for your answer. But the phone works fine when I use it with a clean install, without the backup.
von
alrighty, then then that means your backup is corrupted.
von
Antwort hinzufügen
Uas wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 332
