Zum Hauptinhalt wechseln
The PSP 3000 was released in the U.S. on the 15th of October 2008.
92 Fragen Alle anzeigen
Accidently plugged laptop charger into PSP...
So as I said, wasn't paying attention and accidently plugged the laptop charger into it while it was on. And naturally it instantly turned off, now it won't turn on, and won't charge the battery won't turn on with only the "actual" charger plugged into it.
I've read around about a fuse on the motherboard, but I've taken this thing apart and apparently no one has ever had to fix this TA-095 motherboard because it doesn't have the same set-up as any of the ones I've seen so I don't even know what to try and bridge together. So was looking for some pointers, or if someone knows what exactly the issue might be. Thanks!
Edit: I just grabbed a front/back picture off google of the motherboard since I've already reassembled it for now. Hope thats okay!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
@zantetsuken for now do not apply a jumper to anything. You do wnat to go ahed and post some good pictures of both sides of the motherboard as well as the power board of your PSP3000 with your question. Use this guide Bilder zu einer vorhandenen Frage hinzufügen for that. It will allow us to see what you see.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@zantetsuken the very first thing you want to do is check the power board for any sign of damaged components. After that get your multimeter and check the power fuse for continuity. If it does not have continuity it will need to be replaced.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Where would one find a replacement fuse? I am assuming the power fuse and charging fuse are seperate?
von
Antwort hinzufügen
Chris wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 18
Insgesamt: 2,709
