Zum Hauptinhalt wechseln
Repair information and guides for corded and cordless power drills.
114 Fragen Alle anzeigen
Drill bit stops spinning
Hi,
I am trying to drill a pilot hole but the second the drill bit touches the wall(wood) it stops spinning. The drill keeps spinning but the bit doesn’t. It spins fine when not against the wood.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
It sounds like the chuck is not tightened....does the drill bit stop and the chuck keeps spinning, or does the entire drill stop spinning?
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
The chunk keeps spinning. Just the drill bit stops
von
What model of drill is it? Does the chuck click multiple time when you tighten it?
von
Mine does this very thing
von
Make sure the chuck is tight and ease up on the pressure your putting on the drill. If you putting too much pressure on the drill without the drill spinning fast enough it will bite into the wood and stop moving, and can damage the drill bit shank the part of the drill with out flutes).
Bewertung 0
there is a chuck replacement guide!
Power Drill Chuck Replacement
Bewertung 0
Antwort hinzufügen
Carter wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 25
Letzte 30 Tage: 133
Insgesamt: 20,965
