Zum Hauptinhalt wechseln
Angekündigt im August 2017. Das Galaxy Note8 ist der Nachfolger des durch Rückruf bekannten Galaxy Note7. Erhältlich war das Note8 im September 2017.
148 Fragen Alle anzeigen
Note 8 s pen broke. I want to diy my own note 8 s pen
My note 8 s pen broke. Can you share the technical data on the s pen? I would like to make my own better version of the s pen. I just need the specs or possibly source for the tiny circuit board inside the pen??
Thanks!!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
It isn't that simple. The S-Pen has complex circuitry that generates a electromagnetic field that pulls power from the device you are using it on. The information communicated between the circuitry in the pen and the device is so precise that it knows where the relative position of the pen is, and the pressure that is applied by the tip of the pen.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
^ Essentially, you would be spending much more making it, than to buy an OEM SPen. Im not sure of your requisites as a technologist, but the exact pantent for the pen itself is Copywritten. even their repair technicians only get the parts they need to fix it.
von
You can buy a new Samsung Galaxy Note 8 S pen online, it is not too expensive. Do it yourself may cost more money.
Bewertung 0
1 Kommentar:
My stylus broke. So I bought a new one, samsung brand etc. In the beginning I had a pointer dot, then it became less and less responsive and I had to push the point in the screen to get a response and now it does not respond any more. Only to fingers, in less then two days did the note8 become unresponsive to the new Stylus. So I glued the old one and that one works fine. I am tired of Samsung really and think about changing brands. Before this did I already conclude that their warrenty, their service centre and online help desks are criminal organisations, really! And with the note 10+they cannot keep their own roadmap (5nm) or put the better AI in that they already have. They just want me to buy a new one because it is a bad mobile, with software errors that they do not fix in their new updates. Ever. It is a fixed development program rather than that they LISTEN to the wants and needs of customers who report errors.
Bewertung 0
1 Kommentar:
How did you glue it? Mine just broke it. It's the second a pen to break on me. It still works but doesn't park in the garage easily.
von
Antwort hinzufügen
Thomas Frazier wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 17
Insgesamt: 3,719
