Zum Hauptinhalt wechseln
Repair information for blood pressure monitors (also known as sphygmomanometers).
8 Fragen Alle anzeigen
I used 12v adaptor instead of 6v, now it has stopped working.
Hi,
I used wrong 12v adapter instead of 6v in bp monitor, now it has stopped working. What to do now?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
How can I fix my blood pressure monitor
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi,
You most probably have a damaged voltage regulator and / or other input supply voltage components on the monitor's control board.
You will have to open it up and inspect it for any obvious damage.
Post some close up pictures of any damaged areas on the control board (hopefully it will be obvious but perhaps it won't be) and maybe someone here will be able to help.
Here's how to do it.
Bilder zu einer vorhandenen Frage hinzufügen
War diese Antwort hilfreich?
Bewertung 6
It’s possible it used battery power during the time it worked and due to not getting a charge through the 6v power supply, it’s now drained. Try getting the right power supply and try again.
Bewertung 2
Antwort hinzufügen
Ameit Laal wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 36
Insgesamt: 1,785
