Zum Hauptinhalt wechseln
Repair guides and support for a wide range of Vespa scooters.
14 Fragen Alle anzeigen
Vespa steering column lock removal.
Hi I have removed the steering column on my Vespa LMR Star . But I can't get the steering lock out as I need to replace as the keys are lost. Do I knock it out or is there another way to remove it . I would appreciate any advice you can give me thanks Gerry.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Gerald Murphy LMR or LML Star? If it is LML Star then it will help if you give us the model number as well.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Gerald Murphy it should be riveted in. Post some images of your lock etc. with your question so we can see what you see. Use this guide Bilder zu einer vorhandenen Frage hinzufügen for that. See if this video looks like your lock
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thank's for your help much appreciated.Should have the bike on the road in time for the spring .Gerry.
von
Antwort hinzufügen
Gerald Murphy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 13
Insgesamt: 616
