Zum Hauptinhalt wechseln
Dritte iPad Generation mit Wi-Fi, Modellnummer A1416, erhältlich seit dem 16. März 2012. Die Reparatur erfordert Hitzezufuhr und vorsichtiges Hebeln.
154 Fragen Alle anzeigen
Find a part - what is this piece I’m missing from my iPad?
Hi there,
I’ve opened up an iPad 3 to fix it and unfortunately I’ve been stupid and removed a potentially important part. It was stuck down inside the rear housing. It connected with the LCD ribbon I believe, and I rubbed it off thinking it was a piece of sticky glue left in there. The LCD now doesn’t work (I’ve attached it correctly to the motherboard). The piece I removed must have been an inch and a half long, black and connected to the interior of the housing, on the left hand side looking down on it, about halfway down the side. If anyone knows what this is, it’d be much appreciated if you could let me know so I could replace it! Thank you.
Update (02/12/2018)
this is the missing part
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
4 Kommentare
Can you post a picture of the area where the part is missing?
von
Is it the adhesive strips? They hold the thing together, but shouldn't affect the screen function.
iPad 3 Wi-Fi Klebestreifen Austausch
von
Please post a picture
von
@refectio I ain't got an idea what it is.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Your LCD may be damaged, or the backlight fuse may have went. the battery was not disconnected during your repair.
Another possibility is the battery is completely dead and won't show any signs of life.
The tape is to hold the cables in place and has no bearing on the workings of the device.
War diese Antwort hilfreich?
Bewertung 1
Hello, you can find it here on iFixit, here is full disassembly manual with pictures - iPad 3 4G Teardown
Difference between your picture and picture from this manual is only adhesive strip, look -
It used for hold flex cables in place, just replace it with any other same size dual-side adhesive strip.
Wish you good luck!
Bewertung 0
Antwort hinzufügen
Tom Ford wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 10
Insgesamt: 146
