Zum Hauptinhalt wechseln
The Signet series was Kodak's top American-made 35mm camera line in the 1950's. It is one of only two Signet models that contains a range finder, and the only one not made mostly of plastic.
Why triangle patch is not visible when view through viewfinder
where could I buy a new one beam splitter ,because the coating of beam splitter does not exist and when view through viewfinder the triangle from the rangefinder is not longer visible , and i try using a piece of blank 35mm color negative that has been processed which I put behind the beam splitter, and followed these procedures the triangle of beam splitter is visible , but appears as double triangle, probable first triangle is a reflection of 35mm colour negative film procesed , and the second triangle is reflection of beamsplitter glass.What do you think.Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Your beamsplitter got mis-aligned. Review this IFIXIT guide: Kodak Signet 35 Beamsplitter Replacement. There should be a couple of small setscrews which has some glue on in to prevent it from shifting. One is to adjust the parallax (up & down) the other the infinity set.
War diese Antwort hilfreich?
Bewertung 3
3 Kommentare:
von
This is such an old camera parts will be difficult to find. Maybe you can find a second non-working camera to steal the part from to fix yours.
von
Thank you very much
von
Antwort hinzufügen
Florentin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 24
Insgesamt: 244
