Remove Bench Back Seat
How do I remove the bench backseat?
Ist dies eine gute Frage?
Force the lower end of the bench seat back toward the trunk to release to clips at the bottom of seat and lift out--You will find either clips or screws at the lower end of the upper portion of seat--release these and lift upper section of seat should release from locking clips allowing removal of upper section
War diese Antwort hilfreich?
am amazed by the things you know! ;-)
ah shucks ma'am
How do you get the clips to reatatch thanks
Does anyone know what these locking clips are called? They are broken and I cannot put a car seat in my car because of it. I need to order new ones ASAP
i cannot seem to locate any hardware on mine. looks like its a pin on both sides, and this runs straight into the seat. I've removed the lower seat, cannot get the fold down part out.
if your release strap on your upper backseat is broke, stick a pair of needle nose pliers in the opening right in the middle of the upper backseat grab the latch and pull. now just go do it.....
I took the seat out and broke the clips because I didnt read anything first. Like a idiot. What is the best way to replace the clips? Or just buy a new backseat?
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 35
Insgesamt: 21,721
