Zum Hauptinhalt wechseln
Reparaturanleitungen, Handbücher und Hilfe bei der Fehlersuche für Apple LED Cinema Display 27". Hier findest du alles, was du für deine Apple LED Cinema Display 27" Reparatur brauchst.
Weird distortion on the right side, fixable?
As seen in the picture above, there's a distortion which only appears after the monitor has been turned on for about 30min-1hr. It's practically invisible on white and black backgrounds, but very visible on grey or sky-blue backgrounds for example.
Things I tried:
1. Use a Macbook as source, no fix
2. Use my main desktop as source through DP adaptor, no fix
Is there a way to fix it? Could it be bad caps?
Thank you !
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Here's a good writeup: LCD Image Persistence on the issue. I still call it screen burn-in ;-}
The good news is if you change your background image to a full blue or grey background over time the ghosting will disappear!
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Hopeful news! I will play those YT screen burn-in videos overnight. I'll post an update. Thanks!
von
Update: @danj, you were right! Though it took a while (16hrs), the distortion is almost gone. A little longer and it should be back to normal. Thanks again :)
von
Antwort hinzufügen
Terry Newman wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 449
