Zum Hauptinhalt wechseln
Die Singer EZ-Stitch Kettenstich-Nähmaschine soll Anfängern dabei helfen, ihre eigenen spaßigen und kreativen Projekte umzusetzen. Sie kann zum Anfertigen von Bastelarbeiten, Kleidung, Kissen, Accessoires und vielem mehr verwendet werden.
Thread gets stuck in machine
My singer machine has thread that gets tangled in the machine. I have gotten it out following the book, but it happens again every time I try to sew. I can’t use it at all. I bought it at least 10 years ago & didn’t use it for the first couple years, then we moved. I tried using it & had that problem immediately. I asked my sewing teacher & she told me it would cost more than the machine is worth to fix it. I can’t afford to buy a new one. I picked it up for like $115 at Target. Not the highest model. I also followed instructions for threading.
I have a different model than chosen. It’s a much better machine than this.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare
Its not the machine pictured. I have a full size machine.
von
@magecat any idea what model your machine is?
von
It’s a much better machine than the one pictured. It has several stitches. There is a bobbin beneath the plate, none on top.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Is yours a chain stitch machine like the one pictured, or does it have a bobbin beneath the plate as well as a bobbin in the top?
I wrote up all I know about sewing machines at https://wiki.restarters.net/Sewing_machi... - perhaps the tension is wrong, or the needle is bent, or the timing is out.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
ladycerridwyn wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 15
Insgesamt: 1,727
