Zum Hauptinhalt wechseln
The Lancer is 4 door sedan or 5 door hatchback made by Mitsubishi. The standard model include engine sizes from 1.5-2.4 liters, gasoline or diesel. Transmission options include automatic, standard, and CVT.
How Do I change the Battery in the car key
How do I change the battery of a 2010 Mitsubishi Lancer car key?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
My remote key doesnot work although i change its battary by anew onw
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Pry the casing apart with a looney. (there should be a groove you can open the casing from) then the battery is an easy enough replacement. slide the old one out, and put the new one in.
if you cant open the casing, take it to a local repair shop. should be approximately 40$ for someone to do it.
War diese Antwort hilfreich?
Bewertung 1
To change the battery in a 2010 Mitsubishi Lancer car key, follow these steps:
  1. Locate the small notch or slot on the key fob. It's usually on the side where the keyring is attached.
  2. Use a small flathead screwdriver or a coin to gently pry open the key fob by inserting it into the slot and twisting. Be careful not to damage the fob or scratch it.
  3. Once opened, you'll see the old battery. Remove it by gently popping it out with the screwdriver or your fingernail.
  4. Replace the old battery with a new one. Make sure the new battery is the same type and has the correct polarity (usually marked on the old battery).
  5. Close the key fob by snapping the two halves back together. Ensure it clicks securely.
  6. Test your key fob to make sure it works by locking and unlocking your car.
That's it! You've successfully changed the battery in your 2010 Mitsubishi Lancer car key.
You can also watch our short youtube video showing how to do this: https://youtu.be/Tq-IVqblYtY?si=ltkcQwID...
<iframe width="560" height="315" src="https://www.youtube.com/embed/Tq-IVqblYtY?si=jgXLX6VEsju-N5Tx" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>
Bewertung 0
Antwort hinzufügen
kimlyn gemoya wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 28
Insgesamt: 762
