USB ports problem on modified mac mini late 2006 - El Capitan install
Hi all. I have been updating my late 2006 mac mini. Changed for an SSD, made an efi upgrade and added 4GB of RAM, changed CPU to a T7600. Succeeded in running OSX Lion smoothly. And tried to install El Capitan. It looks like it is installed properly but I can't really tell, I can't pass the password screen of the session : my bluetooth keyboard is not recognized because I didn't have the chance to have it synchronized with this computer under this OS, and when I plugged a USB keyboard, I realized all USB ports are not running (they are are the beginning of the boot, but then not when the system loads). Any idea how I can fix this ?
I have 2 OS installed in different partitions on the macmini : this El Capitan stuck and I can boot to a working Lion (if need to make changes to files in the El Capitan partition).
Cheers.
Ist dies eine gute Frage?
7 Kommentare
I cant remember but you can check if there is a file that you can modify to continue installation without setup on mac ... or Might some kexts can help you with it thereno way to know it if it stack to installation screen . I hope that you can find a logitech unify keyboard or mouse to test it out, from a friend... , that you attach it on usb slot and is generic... you will have more chances to work....
von ssavva05
@mayer probably could help.
von Aiden
Hi Sorry guys I got in a tunnel of work... Thank you so much for answering.
I got a Logitech k120 USB keyboard from work and can confirm it works under Lion. Then at the begging of the boot, I can choose the disk partition / OS I want to boot with using the keyboard, but the keyboard stays inactive when I reach account password step on the El Capitan boot.
I saw posts about kexts but wasn't clear enough for me as I am not a techy. I can follow a procedure but not much more. That's how I modified the macmini so far... Thanks for all this @ssavva05
I will have a look at what @mayer posted and will get back...
von Philippe Jaquet
Have a look here also: https://github.com/TMRJIJ/OS-X-Yosemite-...
This is must be compatible with el-capitan also.
I don't have mac mini to test it, but it might be helpful for you.
You can install waterfox on osx 10.7 (Is something like firefox), to have modern browsing experience to get this workaround...
von ssavva05
Hi again. I saw this page before, indeed. Never had MacPostFactor working but did the manual way of installing on an external drive and patching files and cloning to a partition of the macmini disk. That's how I got here. Maybe I will stop trying el capitan and turn back to Yosemite... Thanks for the waterfox suggestion as well.
von Philippe Jaquet
2 weitere Kommentare anzeigen
