Zum Hauptinhalt wechseln
Released in 2015, the Asus G752VL-DH71 is a 17-inch gaming laptop. It is often referred to by the shorter name G752VL or G752.
9 Fragen Alle anzeigen
Remove and replace optical Drive on G752VL
Can I replace my Optical Drive easily?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I assume you wanna take out the optical drive and replace it with an SSD? It’s pretty simple.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
My DVD drive keeps failing and wanted to put a new one in. I can not find how to do that anywhere.
von
After I made my comment earlier I found out how to remove it. Very simple as you said. Also found that if I removed it from the laptop then put it back in that it worked again. I tried all the regedits and such along with uninstall from device manager and those never worked.
von
Antwort hinzufügen
Patrick Danforth wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 310
