Zum Hauptinhalt wechseln
Mid 2010 Modell A1278 / 2,4 oder 2,66 GHz Core 2 Duo Prozessor
787 Fragen Alle anzeigen
White display - Which LVDS cable do I get?
Hello all!
Backstory: This all started with an LCD that was showing bands of color or white that would fade in and out.
I purchased a replacement LCD from ifixit, installed it, and now I get a pure white screen. All other functions seem to work (keys, volume control, brightness control, etc...).
The Problem: I read up on these forums and decided that my LVDS cable was probably bad. A visual inspection doesn't give away any definite damage, but it does seem generally worn out.
So I got an LVDS cable from an online site that I thought would match mine. The description was for a MacBook Pro 13" Unibody. But when I went to install it, I noticed that it was the wrong size.
The connector is too wide on both ends.
My Question: Does any one know what the varying size LVDS cables are and which one I would need for my model MacBook Pro?
My Info:
  • MacBook Pro 13" Unibody Mid 2010
  • Model - A1278
  • LCD brand - LG
  • laptop serial (last 4) - WATM
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Apple MacBook Pro "Core 2 Duo" 2.4 13" Mid-2010 Specs
Identifiers: Mid-2010 13" - MC374LL/A - MacBookPro7,1 - A1278 - 2351*
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
It seems to only come with the display. Here are other answers to this same question: About LVDS cable MacBook Alu
I found this one: http://www.ioffer.com/i/Apple-A1278-MC37...
and here: http://www.techrestore.net/macbook-pro-1...
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
Those links seem to be to the proper cables.
I wish there was a way for me to know for sure.
I've already bought one for $100 that turned out to be wrong.
Thank you for your answer.
von
Sorry, there is no part number. I would tell the seller exactly which machine you have before buying a second one.
von
The Replacement of wrong screen would burn out your graphic card. i did just same today. bought complete lcd on ebay and turns out it was a macbook air display packed on it. now its white screen,.. an attempt to buy original lcd from apple dealer, all stays white screen and my graphic card is Dead
Bewertung 0
Antwort hinzufügen
nate wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 3,572
