I am getting F09 error code
while in the rinse cycle I am getting an F09 error code. What is it?
Ist dies eine gute Frage?
The F09 error is a water pump problem, either clogged pump, or pump malfunctioning, Check for something clogging the water pump. To do that, open the lower access panel by unscrewing the 3 torx screws at the very bottom of that panel, then you will see the plastic water pump in the middle front, just unscrew the handle, get a few dry towels as some water will come out.
War diese Antwort hilfreich?
You may want to unplug it first before you begin.
Thank you very much. I pulled a wad of gunk out of the pump housing.
Glad I could save you a service call ;-)
Thank you so very much! You have helped us to help ourselves and saved us the needed money. Thank you so much . :)
Thank you! That was exactly the issue we came across last night. The directions were perfect, found one of my daughters hair ties, a rather broken up Lego brick and some hard water calcified build up (we had installed a water softener some years ago, so this may be some "historical" break up). Ran a load today and no code, no issues.
hi i have f9 display always when i start machen can you help with this
We have also been getting the F09 code but only on Delicate cycle, not on Normal cycle... It does it 5 minutes before the end of the cycle and will only move forward if we turn it off and then back on. It then runs the remaining 5 minutes.
I too keep getting this code in the exact same manner you describe. Did you ever find out why? (we just had Sears repair out yesterday and replaced the pump)
Letzte 24 Stunden: 5
Letzte 7 Tage: 23
Letzte 30 Tage: 115
Insgesamt: 31,284
1 Kommentar
There was a penny inside my water pump. Follow the instructions on how to check the inside of your water pump and you will likely find the problem.
von Frank O
