Zum Hauptinhalt wechseln
Seventh generation laptop released in 2015. The Alienware 17 R3 is a high performance gaming laptop.
How to remove head phone jack from alienware 17x r2
the head phone jack got broken with part of it left in
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
iFixit sells a tool which can remove broken headphone jacks. It's called the GripStick, and you can find it here: GripStick Headphone Plug Extraction Tool
This is designed for professional repair techs who have become familiar with the process over time, so it can be tricky to use at first. Occasionally, the GripStick needs to be pinched slightly near the tip in order to fit, but they do require a bit of skill and finesse to use them successfully.
Please note that the GripStick does not have any warranty whatsoever, so there's no guarantee it'll remove the broken bit in your computer, and no returns are accepted.
GripStick is a tool designed to easily remove broken 3.5mm headphone plugs from jacks Bild
Produkt
$24.99
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
gaary8354 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 249
