Zum Hauptinhalt wechseln
Veröffentlicht im April 2010 / 2,4 GHz, 2,53 GHz Core i5 oder 2,66 GHz, 2,8 GHz Core i7 Prozessoren
590 Fragen Alle anzeigen
Hard Drive issue-mount point: Not mounted
My MacBook Pro will not boot past the Apple logo with the loading bar. When I went in to the disk utility and tried to verify the disk I received, "Error: This disk needs to be repaired. Click Repair Disk. I did so and after it tried multiple times it gave me the errors, "Incorrect Number of thread records" and "invalid volume file count" at the end it says "The volume Macintosh HD could not be repaired after 3 attempts"
What are my options?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Replace the drive. That generation is pretty easy. You should go download the operating system to a bootable USB before you start: Macworld - How to Create a Bootable MacOS Sierra Installer drive
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
@matt2015 & @metaldog - Besides replacing the drive I would also replace the HD SATA cable as they have been known to breakdown over time. I even add some tape under it where it rests on the uppercase as the rough aluminum is a common cause of the wear.
von
Antwort hinzufügen
Matt wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 831
