Zum Hauptinhalt wechseln
Device repair and troubleshooting guides for the HP Pavilion 13-s128nr x360, a consumer 2-in-1 laptop by HP released in September 2015.
21 Fragen Alle anzeigen
How to fix "plugged in, not charging" in HP Pavilion 13-s128nr x360?
When the AC adapter is plugged in, it is shown "plugged in, not charging" and the battery light indicator does not come on. How could this issue be fixed?
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar:
It sounds like the charger is not sourcing enough current to the laptop. Are you using the charger that came with the laptop, or an aftermarket charger/charger for another HP laptop?
von
Einen Kommentar hinzufügen
3 Antworten
a few different things can cause the error youre getting.
1) Make sure the full voltage is coming from your AC Adapter. :::: Adapter may need to be replaced.
2) Make sure your Port is accepting a Charge :::: Port may need to be replaced
3) make sure your battery is accepting the charge from your adapter. (proper voltage at the pins while charging) :::: This is usually a logic board failure.
4) Make sure your battery is good. (replacing it is the most simple way to do this.)
If any of the above is failing, fix accordingly.
War diese Antwort hilfreich?
Bewertung 0
i’m having the same problem, it happened after I used a 12v to 120v converter in a car, it makes a buzzing noise and something might be fried, it works if I unplug and plug it in like 1000000000 times
Bewertung 0
1 Kommentar:
i'm buying a new plug to see if that's the problem
ps. I'm using a HP pavilion notebook from 2016
von
Did you upgrade to windows 10? I seems this is a driver issue with the battery controller. im still researching it but the charging works under Windows 8.1. Once you go to 10, it's over. Microsofts battery driver overrides the original HP driver and doesn't enable charging while plugged in.
Bewertung 0
Antwort hinzufügen
jasmindubellay0784 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 17
Insgesamt: 5,285
