Zum Hauptinhalt wechseln
Modell von 2011, A1278 / 2,4 GHz i5 oder 2.8 GHz i7 Prozessor.
591 Fragen Alle anzeigen
Battery not charging, not detected in OS.
Hi!
I recently took out my sshd to test another hard drive / cable. Before I unplugged the harddrive, I unplugged my battery from the main board.
Upon reinstall of my harddrive and reconnected the battery, the battery no longer is detected.
I recently noticed that my battery indicator on the left side of my MacBook Pro Mid 2011 13 Inch Unibody is no longer working either. The laptop will only work when plugged in.
The battery is not detected when I go to system / power.
I have ordered a new battery from IFixit and no success. I have tried the SMC reset and all the other reset procedures but nothing. I’m out of ideas.
There was no water damage or other issues before.
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare
Disconnect the battery tester ribbon cable and see if the system works that way.
von
Yes the computer works when the battery ribbon is disconnected and computer is connected with the MagSafe charger.
von
So I disconnected the ribbon cable that is next to the battery plug. The laptop works still. So what does that mean?
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Just so I'm sure here, this is the ribbon cable you needed to detach marked in Green:
If that made a difference then you have a bad tester which is just behind the battery.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Sorry, I’ve been busy with school and homework. I disconnected that circled part and the laptop still works when plugged in.
von
There may have been a static discharge if it wasn’t grounded properly, which could lead to a slew of issues.
Try to see if the dc magnetic safe inboard has gone bad. When I replaced my battery, I had a similar issue.
Hope this helps! Let me know if it fixed it or not.
Bewertung 0
1 Kommentar:
I had the computer on a desk but did not have an anti static strap on. I’ll have to check the MagSafe strip.
von
Antwort hinzufügen
Song Cheng wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 5
Insgesamt: 106
