Zum Hauptinhalt wechseln
Rockchip Quad-Core RK3288C Processor, 11.6" 16:9 HD (1366x768), 16GB eMMC, Integrated Rockchip® Mali T764, LPDDR3 MHz SDRAM, OnBoard Memory 2 GB / 4 GB
18 Fragen Alle anzeigen
certain keys wont respond
Letters and numbers such as (8, i, k,) wont apear on the screen when I press on them , what do i do ?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi Salma Repole
Try following this step below to dismantle your keyboard
Asus Chromebook C201 Keyboard Replacement
there is a lvds cable which is connected to the mainboard. Disconnect it carefully and clean up your keyboard.
Use an eraser to rub on the LVDS cable connector of the keyboard module and reconnect it back.
Test your keyboard, one good link to test and spam the keys...
http://www.keyboardtester.com/
Launch It and test...
If all fails, consider getting a replacement keyboard module from ebay.
https://www.ebay.com/itm/New-Asus-Chrome...
War diese Antwort hilfreich?
Bewertung 2
Hi,
Here are some possible fix -
  1. Update Windows
  2. Update Keyboard Drivers
  3. Install/Uninstall the keyboard drivers
  4. Plug and unplug the keyboard
  5. Try keyboardtester.org
Hope these steps will help you to make your keyboard working properly.
Bewertung 0
Antwort hinzufügen
Salma Repole wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 2,399
