What does CL mean
My washer flashes CL when I power on. Will not let me choose cycle and will not start
Ist dies eine gute Frage?
The Kenmore Elite HE3 is a washing machine by Kenmore.
From Kenmore elite washing Machine Code error CL, control locked?:
This error code most likely indicates that the CONTROL LOCK has been activated. To deactivate the control lock press and hold the drain and spin button for 5 seconds. Or you can try to reset it by unplugging your machine, and plug it back in after 5-10 min.
I had the same problem. I tried unplugging for more than 10 minutes. Did not resolve. There is no Drain and Spin button. I pressed and held the Extra Rinse button for a number of seconds. It did clear.
Kommentare:
I tried unplugging and also holding down the extra rinse button...still CL. I called the diagnostics number, and he said it was locked, so I held down the Chime button for a few seconds and it cleared. Washed is running fine!
Thank you! It was the Chime button!
von reinaim
Man I love the Internet… Thank you it was the chime button :-)
von Debra Trudell
Chime button worked for me too....thank you!
von chrissiegammon
Pressing the Extra rinse did it for me too. Love this way to get info
von darlenep59
Letzten 24 Stunden: 3
Letzten 7 Tage: 44
Letzten 30 Tage: 201
Insgesamt: 7,120
I had the same problem (CL Code) with my Kenmore HE front loading washer ( Model 796.4168). This Trouble Code is not in the Use and Care Guide provided with the machine. The first deactivate instruction doesn’t work. There is no “drain and spin” button on this machine. When I was reaching over the machine to unplug it (the alternate deactivation instruction) I bumped something on the control panel, heard a beep and the CL code was gone. What did I press to (apparently) reset the Control Lock?
von gthrone
I had exactly the same problem. Based on your comment, I pressed extra rinse for a few seconds and it cleared the CL. Works again!
von Maureen Ekman
I have exactly the same problem. I unplugged the machine for a period of 20 minutes, I pressed the ‘Chime’ button down for extended period, and still doesn’t reset the error. There isn’t any ‘Spin’ or ‘Drain’ buttons. Do you have any ideas?
von Brant Jackson
I have the same error, neither of the above solutions worked. I called every company I could. No answers. Help.
von lisalive86
I have a control lock button and held it down and the error code cleared, I think that happens mostly when you accidently lean on buttons when reaching over the panel .
BabyDoll
von ELLIE
2 weitere Kommentare anzeigen
