Zum Hauptinhalt wechseln
2,3GHz, 2,6GHz oder 2,7GHz Quadcore Intel Core i7 Prozessor (Turbo Boost bis zu 3,7GHz) mit 6MB geteiltem L3 Cache.
561 Fragen Alle anzeigen
Internal SSD only recognized when booting externally.
Hey there,
i have a weird problem with a MBPr 15" Mid 2012. Lets call it MBPrA.
MBPrA has a broken SSD but boots normally from an external drive.
I removed the SSD from a non working model from the same year (MBPrB) and put it in MBPrA.
MBPrA doesn't boot and i get the ?-Folder sign.
When i boot MBPrA from external again the new internal SSD is recognised normally and i can browse files on it. The SSD definitely has a system on it.
I'm really really confused...
I also need to mention that the SSD is APFS formatted on High Sierra. MBPrA hasn't been upgraded in a while and might last have run on 10.11. Is it possible it didn't get a firmware upgrade that is needed for APFS?
Thanks in advance!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
The drive needs updating (newer APFS). Your systems is expecting the newer APFS file system from what it has in its NV-RAM setting from your other drive.
From your external bootable drive re-install the OS onto the older drive. That should fix it.
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
Thanks for the quick reply!
I'm not sure i understand. The SSD i want to use already has 10.13.4 installed on it. I can't do anything with the other SSD anymore, it isn't recognised properly when connected from an external case.
The MBPr i want to use is not recognising any APFS drives (also tried another MBPr in target disk mode) internally or externally when booting with the alt key.
It does however recognise them fine (internally and externally) when i boot from an external drive (non-APFS) which has 10.13.4 installed.
Sorry i know this probably all sounds a bit convoluted.
von
OK so I got it reversed! Same deal but the systems EFI firmware needs to be updated so that system can see the newer APFS drive.
When you re-install the OS the firmware of the system will be updated.
von
Ok i'll try that, thank you!
von
Antwort hinzufügen
DoktorMac wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 453
