Zum Hauptinhalt wechseln
The Toshiba 40PB200 is a 40-inch flatscreen television in the PB200 series. It was released in 2012.
36 Fragen Alle anzeigen
Was watching it then picture went out but have perfect sound. .Turned
I have a 47" Toshiba smart LED t.v. and was watching it then picture went out the sound is perfect. I turned it off and on and did not work so I unplugged everything for half hour plugged back in and still no picture?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
'''++Barbara Martin++'''  let us know the exact model number for your TV. Since you have sound but no pictures it is possible that your backlight has failed. In a darkened room turn you rTV on and to a channel that you know is on the air. Then shine a flashlight at an angle against the screen, see if you can make out silhouettes etc. Then you will have to remove the back off your TV and take a look at all the boards and wiring. check for obvious damage like blown leaky caps etc. Post some images of your boards with your question so that we can see what you see. Use this guide Bilder zu einer vorhandenen Frage hinzufügen for that.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Barbara Martin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 81
