Zum Hauptinhalt wechseln
Die PlayStation 2 wird oft als "PS2" bezeichnet. Sie kam in Japan im März 2000 heraus. Reparaturen erfordern nur ganz normales Werkzeug, sind aber manchmal etwas trickreich.
Why is my ps2 not displaying pictures?
My ps2 is not showing any pictures just a screen with a zipped image like not even showing the main place where you wait for the game to open, just no image?
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
my tv looks like nothing is connected to it
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
okay so ive got a little bit of confusion on what you are getting. a zipped image to me, is the torn file image you get from a bad file, but no image means the screen is black.
The later can be caused by a bunch of issues.
1) Verify your connections: check your AV cables, and ensure they are in the correct places, and tight enough on each connector.
2)Verify continuity of cables: the easier way to verify your cables is to purchase a new set of them, however, you can also us a multimeter and the data sheet to test that the pinouts are in tact.
3)Possible Settings issue: Try a factory reset on the device. (Turn on the system with nothing in the tray so it will load into the dashboard. Press DOWN and then X. Hit DOWN, DOWN, DOWN then X then LEFT then X again. )
4) Port Damage: The connector to you system, OR The AV Cable connectors on your TV could have been damaged. Replacing these ports would fix your issue should this be the case.
5) Board level failures: You very well could have a GPU or related circuit failure on the logic board. In which case, a logic board replacement should fix your issue.
War diese Antwort hilfreich?
Bewertung 3
I heard a black screen can be caused by a bad nand
Bewertung 0
Someone has put a zipped file on your device. It is a type of computer (in a way). You have to have software to open the zipped file.
Bewertung 0
Antwort hinzufügen
Yousif Shakeeb wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 14
Letzte 30 Tage: 43
Insgesamt: 20,050
