Zum Hauptinhalt wechseln
Einige gebräuchliche und weniger gebräuchliche Kabel, die bei Computern und im Haushalt verwendet werden.
32 Fragen Alle anzeigen
Solder lightning connector car charger
is it possible to weld the lightning connector of the following charger for iphone 5?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi @piero90
WARNING, please do not directly solder and use it.
Cigarette adapter in cars output mostly is 12V
https://www.nonda.co/blogs/news/13486157...
USB uses 5V.... direct 12V can kill your devices
If you see the USB 2.0 wire layout.... there are four cables vcc, d-, d+, gnd
https://www.chipworks.com/about-chipwork...
I would suggest you to get a cigarette adapter to USB charger as it has been converted to 5V and USB standards. You only need to get MFI certified lightning cables to charge your apple devices.
https://paracable.com/pages/what-is-appl...
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
ITS BERY GOOD TO KNOW HOW TO DIY BECAUSE MABE YOU MIGHT HAVE JUST A LOT OF DIFFERENT PIECES OF THIS AND THAT BBUT YOU MAY HAVE A. Part you need IN & .B. A DIFFERENT PART YOU NEED OUT. BUT ALL YOU NEED TO KNOW HOW TO PUT UT TOGETHER THE RITE WAY WITH OUT ANY INJURIES. OR GETTING HURT IN ANY KIND OF WAY…
von
is it possible to reconnect the cable to the lightning connector that has come off?
Bewertung 0
4 Kommentare:
Hi @piero90
Give you an idea what is inside,
https://www.youtube.com/watch?v=kjEBbGWg...
but as commented earlier, do not connect or solder it directly to use in direct to the cigarette adapter.
von
How can I fix it?
von
@piero90
https://thewirecutter.com/reviews/best-u...
Get this and put in your car, get a new USB lighting cable.
von
So I can’t repair it.
von
Antwort hinzufügen
Piero Sabino wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 933
