Zum Hauptinhalt wechseln
2,26 oder 2,4 GHz/ weißes Unibody-Gehäuse aus Kunststoff
645 Fragen Alle anzeigen
Why cant I upgrade the RAMs for MacBook7.1
i got two 2G ram but failed to upgrade to 4G but i couldn't . i was only able to reach 3G. one of the original rams has to be installed for it to work.
so i decided to try different ones after reading lots of forums on here , I got two 4G ram however it refuses to boot with them both. Only one of them with the original 1G ram.
I have tried all possible combinations and cant get more than 5G
Its very frustrating to read that some are able to get it to work. Any tips??
what am i missing, why does it need the original 1G ram.
Macbook 7.1 mid 2010
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
You have to put the correct TYPE of RAM in it:
RAM Type:PC3-8500 DDR3Min. RAM Speed:1066 MHz
https://everymac.com/systems/apple/macbo...
UPDATE
Go here and input the serial number to see EXACTLY which machine you have:
https://everymac.com/ultimate-mac-lookup...
Apple MacBook "Core 2 Duo" 2.4 13" (Mid-2010) Specs
Identifiers: Mid-2010 - MC516LL/A - MacBook7,1 - A1342 -  2395*
Standard RAM:2 GBMaximum RAM:16 GB*
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
those are the type i am using, plus i have tried all the modules i got and each work separately with the original 1G
von
What is your model looking it up from EveryMac? Post the systems URL so we can see what you've got from the link Mayor posted.
von
Antwort hinzufügen
Kareem wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 328
