Zum Hauptinhalt wechseln
Die dritte Generation der Samsung Galaxy Note Phablet Serie wurde am 25 September 2013 veröffentlicht. Es trägt die Modelnumer N9005.
248 Fragen Alle anzeigen
Getting hot around the camera and battery draining
Hello.
I have Samsung note 3. It gets hot upoer part of the back and around the camera. It drain the battery really fast. I bought a new battery and it is the same thing. Getting hot and draining the battery fast. Any help? Thank you.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hi Aden Crater, Sorry to hear your having Trouble with your Note 3.
This is most likely just because theres a few applications running in the background then the phone can handle and your ram (random access memory ) might be a little backed up. first you'll need to clean up all the temporary files located on your phone, this can be done with a program called ccleaner (you can find it on the play store) just intall and run its cleaner to get your phone in order. Learn how by useing the following link:
http://bit.ly/androidccleaner
Next, you'll want to limit the amount of applications running in the background. Check out this neat form below that will walk you through it
http://bit.ly/applimitaionsandroid
If you have anymore questions fill free to email me at dextech87@gmail.com
Best Regards,
Devin A. Stokes
Repair Technition
DexTech Solutions
War diese Antwort hilfreich?
Bewertung 0
I don’t know.haha…
Bewertung 0
1 Kommentar:
I have this problem too. haha
von
Antwort hinzufügen
Aden Crater wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 10
Insgesamt: 1,607
