Zum Hauptinhalt wechseln
Mid 2010 Modell A1278 / 2,4 oder 2,66 GHz Core 2 Duo Prozessor
794 Fragen Alle anzeigen
Liquid damage and backlight not working?
My LED backlight is not working and have read various other posts with the same problem and it has been suggested it is a fuse (part 0402) Detailed Logic Board Question. No Backlight..
I have the Macbook Pro 13" 2.4Ghz 2010 model and the logic board is slightly different to the 2009 model so I need to confirm where the fuse (part 0402) is exactly. I have taken several photos of the logic board where the LVDs connector is http://s1206.photobucket.com/albums/bb44... and from what I have read and photos i've seen of the 2009 model http://img826.imageshack.us/img826/1204/... it should be located around the LVDs connector. I just need confirmation of the correct fuse before I try and replace it.
Any help much appreciated.
Added by edit
Also I had a spillage on the keyboard which resulted in the backlight not working. The only other thing that has happened since the spillage is the laptop works with the power cable attached (No light amber or green on the connector) but still charges the battery even though it say's 'NOT CHARGING'. Apart from the 2 issues everything else works just fine. I have a Macbook Pro 15" 2.53Ghz A1286 mid 2008, would the LVDS cable fit the 13" 2010 just so I can try before buying a 13" LVDS?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
8 Kommentare
Thanks for your post. This is the original forum I read regards this issue
http://att.macrumors.com/showthread.php?...
See what you think if you haven't already seen it.
I've not got a multimeter but I'm planning on getting one to help diagnosing this problem. Thanks for the edited photo, the one you've marked fuse, is that the fuse mentioned in these forums(fuse part 0402)?
Cheers.
von
If it was the LVDS cable would you still be able to see a faint image on LED when you shine a torch through the Apple on the back lid?
I've not mentioned either, I had a spillage on the keyboard which resulted in the backlight not working. The only other thing that has happened since the spillage is the laptop works with the power cable attached (No light amber or green on the connector) but still charges the battery even though it say's 'NOT CHARGING'. Apart from the 2 issues everything else works just fine.
von
Or thanks, i'll give that ago and let you know. Before i do just a few questions to make sure. Would distilled water do the job just as good as rubbing alcohol. Can't find rubbing alcohol 95% or better, only 70% off eBay UK. Can you confirm which is the LP8543 WLED driver so I make sure I do the job correctly.
Many Thanks for all your help so far, it is much appreciated.
von
I bought some Isopropyl Alcohol 99.9% which i'll be using to clean the logic board tomorrow. Thanks for the recent update. I'll keep you posted.
Thanks Again.
von
Hi, I have cleaned the logic board like you suggested but the backlight is still not working. I have acquired a Macbook 1278 LVDS cable, not the Macbook Pro LVDS cable. Would this cable fit my model? What would you suggest doing next? Thanks.
von
3 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Thank you for the added information. I understand why you believe the problem is on the motherboard now. Please remove and clean your motherboard with isopropyl alcohol and a brush. Be liberal with the alcohol, don't worry about using too much. Instructions for removing the motherboard are here. I would suggest using pharmaceutical grade rubbing alcohol (95% or better)which you can get at many drug stores, since it will evaporate readily. You can actually use distilled water. What ever you use let the motherboard sit for several hours after you remove it to discharge the capacitors before cleaning it. Liquid will not hurt the board or components if there is no electricity present. Batteries and capacitors store electricity. After you clean it dry it with a hair dryer , no heat, or a fan to expedite drying. Be sure, be comfortable, that all is dry prior to re-installing the battery and the power source, let it sit over night. Now give it a try again. Doing what I have suggested here is where we need to start we must be sure there is no residue or contaminates on the motherboard or it's components before we can say that anything is bad or needs replaced. If you have already cleaned it once, please do it again in the manner I have asked at the very least to entertain me. Sometimes it takes more than one cleaning to get rid of the residues. You have mentioned multiple problems perhaps we can eliminate some or all of them with this.
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
Thanks, I'll give that ago. Before I do would distilled water do the job as good as rubbing alcohol? I can find rubbing alcohol 70% on eBay UK but 95% and above no luck. Can you confirm which the LP8543 WLED driver is so I can be sure i'm doing anything correctly. Thanks for all your help so far, it's much appreciated.
von
Antwort hinzufügen
Spidey76 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 5
Insgesamt: 8,127
