One beep with black screen, unable to start
Hi
Been reading all answers, but my situation is a bit different. We have decided to upgrade an old MB Pro mid 2010 with 2 x 4GB RAM and SSD. Looking through the MB before upgrade, the battery suddenly started to bulge up and actually twist the entire frame and push the trackpad up. I immediately removed the battery, and tried the MB with just powercable connected. All worked fine. However, next morning before starting the upgrade I turned on the MB - or tried. Black screen, and single beep.
I have then tried all possibilities, PRAM and SMC reset, cleaning of RAM slots, new 4GB RAM in both slots, all to no avail. Even tried to undo and retighten (lightly) the 4 screws holding the RAM socket.
Any suggestions? I am afraid that the swelling of battery and subsequent twisting og entire frame could have damaged the logic board? But if so, how come it worked for several hours after battery removal?
Ist dies eine gute Frage?
Is the single beep repeating after a few seconds if you keep it on ? or just a single beep and that's all ?
von arbaman
It continues with same interval (approx 3 secs) until I turn it off. And the white LED on front blinks with it.
von soren
That sounds like a Ram issue, have you already tried reinstalling the old sticks ? Sometimes for apparently no reason, perfectly working Ram on one machine won't work on another and viceversa.
Your new sticks are pc3-8500 ?
von arbaman
Yes, tried all options with RAM. There was one 4gb already installed, moved it to the other slot. Installed new RAM in first one slot, then the other. And tried to mix the old and new 4gb slot in both slots. Absolutely to no help. And the RAM is confirmed to be correct, Crucial 4GB DDR3 - 1066 SODIMM (Specs: DDR3 PC3-8500 • CL=7 • Unbuffered • NON-ECC • DDR3-1066 • 1.5V • 512Meg x 64 • lead free • halogen free • for Mac)
von soren
A Ram problem after resets and different attempts at ram sticks exchanges leaves us with a logic board issue. I'm not able to think about other alternative explanations, would need deeper testing on a workbench.
von arbaman
2 weitere Kommentare anzeigen
