Zum Hauptinhalt wechseln
"The worlds smallest 15.6-inch laptop packs powerhouse performance and a stunning InfinityEdge display all in Dell's most powerful XPS laptop."
What screwdrivers do I need to disassemble the xps 15 9560?
What screwdrivers do I need to disassemble the xps 15 9560? I need to change the HDD to a SSD.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Needed screwdrivers:
-Phillips screwdriver #0
-Phillips screwdriver #1
-Torx #5 (T5) screwdriver
https://topics-cdn.dell.com/pdf/xps-15-9...
The IFixit toolkit is very much an overkill, but I might get it so that I'll have all future screws needed. (And hopefully it is of a better quality than their less pricey competitors)
War diese Antwort hilfreich?
Bewertung 0
Hilfreichste Antwort
The majority of Dell laptops use #0 or #00, depending on the system, and screw location. For the SSD it's usually #00 whole the other screws tend to be #0 due to the nature of the M.2 screws making this unavoidable.
However Dell is known to secure the XPS machines externally with T5 or T6 Torx screws but that's where the Torx shenanigans end. They've done it for a while on these XPS laptops.
My recommendation for a laptop like this is to get the 64-bit driver kit so you aren't stuck if my educated guess is wrong.
iFixit's 4 mm aluminum screwdriver handle with magnetic bit socket, knurled grip, and swivel top — plus 64 essential precision bits to tackle sneaky security screws. Bild
Produkt
Mako Driver Kit - 64 Precision Bits
$39.95
Bewertung 2
Antwort hinzufügen
Alessandro wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 31
Insgesamt: 23,744
