Zum Hauptinhalt wechseln
Repair guides and support for televisions manufactured by Sony.
Image Issues Blue Lines os screen
Hi Guys
I have a Sonvy Bravia model KDL-50W685A that i bought at 2013 . Suddenly the screen initially start to have pixels randmly like when loos the HD Signal . but after that shows horizontal blue lines . The sound working ok and the channels change also .
I try to recycle the power and i leave it all night closed but this is not solve my problem .
I attach the photo with the problem .
Any ideas would be appreciated .
Update (07/07/2018)
Hi to all
I reseat all the cables for the board to panel bust still the same issue .
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
@costasc
please attach some pictures of what your screen shows. Use this guide Bilder zu einer vorhandenen Frage hinzufügen for that.
Horizontal lines are almost exclusively a panle fault. Once we see what your panel shows we can hopefully get you a better answer.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
I would suspect poor connections to the panel. Open up the TV and re-seat all of the cables. Start there and update this with the results.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Hi Dan
Just to clarify , you mean the connection inside the tv and not the aerial cable
von
That is correct. Since the signal level between the logic board and the panel is so small, it does not take much corrosion or dirt to cause a problem. Simply removing the cable and reinserting it often will "cure" the problem.
von
@costasc
that could be a main board issue as well as a panel issue. I would start with the main board, checking the t-con board as well. disconnect all teh wiring form the T-con board to the panel. then just connect one side. Let us know what it shows.
Bewertung 1
Antwort hinzufügen
Costas wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 177
