Zum Hauptinhalt wechseln
Das Galaxy S6 ist das neue Flagschiff der Galaxy-Linie. Es wurde im März 2015 angekündigt, Verkaufsstart war am 10. April. Die Version mit dem gewölbten Bildschirm ist unter Galaxy S6 Edge bekannt.
487 Fragen Alle anzeigen
Fast charger charges other devices, but not one particular phone.
I have a customer who has a Galaxy S6 with a fast charger. The fast charger charges other Samsung devices quickly, even with the same cable. Has anyone seen this be a charge port issue before? I have only seen this as a cable or charger adapter.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
This charging problem is fairly common I think. It is to do with a faulty charging port. You will have to get the charging port replaced and it will work fine. I used to have this problem I temporarily fixed it by putting a toothpick in the charging port and prying the thing inside th charging port up a little but I definitely wouldn’t recommend this. Better safe to just get a charging port replacement
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Yeah sounds like charging port needs to be replaced. OP should make sure it gets done via soldering replacement and not the daughterboard replacement as that is high risk in damaging the screen.
von
As my bio states, I've been in the business for over 2 years, and my company seems to have good luck with pulling the screen for the ports. Thank you both for your help.
von
Antwort hinzufügen
Charlie B wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 55
